Results 1 to 5 of 5
Thread: Throttle Body Shaft Seals Now Available
    We had some requests for throttle body shaft seals, so here they are. Get rid of those nasty boost leaks coming from your throttle body and get back that lost horsepower.
    Throttle Body Shaft Seals for 3000GT, Stealth, 91-99 DSM, and Evo 8 & 9 | Ground Zero Performance
    TN
    Are those the ones with the plastic reinforcement? Have you test fitted these by chance, because I found them slightly larger (OD) than the stock ones... which makes them a bitch to fit. You should get some Mil-Spec shaft seals as another option, like OEM (metal reinforcement) but the inner seal is much better.
    These are constructed just like a normal seal. It's the same seal that all of the DSM vendors sell. I'll put some in a TB here at the shop later today. Lord knows I need to rebuild a TB for Em's stealth anyways
    TN
    They look like the ones MachV sells, except yours are cheaper... I found them very difficult to install without ruining the outer casing (it sort of "shaves" a little bit of plastic off because it is ever so slightly larger than the bore on the TB). The ones made by Mil-Spec look just like OEM except the inner seal is more substantial, and press in perfectly.
    Thanks for the insight. I sent them an email. So we'll see where that takes us
