Page 4 of 4 FirstFirst ... 234
Results 31 to 34 of 34
Thread: New Engine Build - Death to 10:1
  1. #31
    JNS Engineering verified
    San Jose, CA
    In for updates Greg. I would like to take my engine rebuild through a similar process. I think I found a shop to clean my heads after I strip them but haven't located a machine shop that could hot tank and hone the block.
  2. #32
    Never finishes any verified
    Wake Forest, NC
    No real updates right now.
    I just sent my coolant neck off to get powder coated.
    Boxing up the last of the nuts and bolts to mail them off to the plater to get a clear zinc treatment.
    Waiting on Gates to get some kevlar timing belts out to Chris.
    In the mean time I took the car out last weekend to do some tuning runs. Only got one good tune run in due to the front end breaking up really bad. I got a new CV Shaft sitting next to me that I need to install and over look the front suspension. 120mph with the front end breaking up was not fun!!! But that one run did net me a good log to run through virtual dyno...
    This was only at 8psi and little rich of a tune as I didn't get a chance to tune the fuel to accommodate the water/meth injection.
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
  3. #33
    Wake Forest, NC
    Here are the recent updates I have on the engine build.
    Timing kit came from Ninja Performance. Gates Kevlar timing belt, and Ninja Solid tensioner.
    I got the water housing back from Terry @ Maximal. It looks amazing and I am extremely happy with the quality of work that was done.
    I finally got my parts back from the plating company. It only took 3 weeks but in the end it was well worth it. The plating is almost chrome looking!
    I got the timing kit and water housing installed. I'm in the proces now of swapping out all of the stock hardware with the plated ones. I have decided that even though the engine done to the point I can install it, I will not be dropping it in this year. I just put my house on the market as the Wife and I are looking for something larger with a shop for me to work in. So with the house showing and moving in the near future there is just too much going on. i am just going to stick with tinkering and getting everything I can done on the engine. now on to the pics!!
  4. #34
    Wake Forest, NC
    So I trashed the timing belt on the 10:1 engine this past weekend so the engine swap will begin. This block is for the most part done and anything missing will come off of the 10:1 motor. I started a new thread for the actual swap portion of the build which you can follow here:
    http://www.3sgto.org/3000gt-stealth-...ransplant.html
