Results 1 to 6 of 6
Thread: Propeller shaft boot
    St.Louis
    Just inspected the boot on the lobro joint on my propeller shaft and it is missing completely. Where can i get a new one? Ive looked on cherry hill but im not sure what to buy.
    Ann Arbor, MI
    CV Axle?
    Just replace the axle with a reman from NAPA or Autozone.
    Newark, DE
    He's talking lobro joint on driveshaft (propeller shaft in manual), not a half shaft.
    You can source oem but it's pricey. I ended up biting bullet & buying a lightweight aluminum 2 piece driveshaft.
    Sent from garage
    91 AWD TT
    St.Louis
    Yea on the propeller shaft not the axles. Just found that my rear drivers side axle boots are torn, should i get boot kits or should i just order a new axle for it? Back to the Lobro joint, does anyone know the part number for the boot possibly?
    Newark, DE
    http://www.3sgto.org/f17/drive-shaft...boot-6238.html
    Hans identified the part number in this link...
    There are also some interesting youtube videos from mitsubishi on this, which I cannot access from work.
  6. The Following User Says Thank You to Roybatty For This Useful Post:
  7. #6
    St.Louis
    Thanks a bunch man!
