Results 1 to 2 of 2
Thread: Wanted: two front seatbelt buckles for 97 vr-4
    I need to replace the front seat belt buckles, or receivers that were damaged during the hurricane.
    The mechanism works but the electrical contacts inside were corroded and need to be replaced.
    These are the things that the seatbelt clicks into and turn off the seat belt light
    St.Louis
    Still need the buckles? If they are the same across all years then I have a set from a 91.
