Results 1 to 10 of 13
Thread: 6sp swap
    6sp swap
    About to purchase a 93stealth rt turbo .. Since its a 5sp how hard is it to swap a 6sp into it ?? Like parts needed ? And is it worth it ? I'm thinking better overdrive , closer ratios .. Am I wrong or can it even be done
    Stick with the 5 speed. Its stronger overall. Just get a transfer case brace if you plan or drag racing.
    You'd need the transmission, transfer case, rear differential, driveshaft, and shift cables.
    Yes I plan on dragging it a few times a month .. So maybe I should get the brace .. Anything else it will be a Dailey driver too .
    Is 94 the first year the Stealth got the 6sp
    Yeah, 94 was the first year for the 6 speec in the TT's.
    Stick with the 5 speed. The 6 speeds have a weaker bellhousing. 5 speed also has more advantages with gearing when it comes to dragging.
    Good cause I prefer that body style too .. Thanks for the info ..
    I like the 6-speed better for a DD. cruising down the highway at 3K+ RPMs gets old.
    1993 rt/tt Not Verified
    wa state
    lol, wait a sec...ive been daily driving mine for over 8 years, what speed are you "cruising" at, 92?!?
    Quote Originally Posted by wingnut View Post
    something like that. second I hit the freeway I set cruise at 90 MPH.
    wa state
    Ah, ok then...Id guess 265/35 tires too, was trying to figure out how you got over 3k
    But when im doing 90, engine drone is usually the last thing on my mind
