Results 11 to 20 of 50
Thread: Stay away from Lucas Oil Additives!
    Cazenovia, NY
    This has been known by enthusiasts for a LONG time... but good information to pass along.
    welcome to 1998?
    Advanced Tech? verified
    Quote Originally Posted by TwoXist View Post
    To be honest these are just some pictures. So until i see it myself i am gonna keep using it.
    show us a picture after you drain a hot engine?
    No BS
    Sorry if you care, I could be lying anyway!
    NJ (south)
    The biggest problem I have with that demo is that all he is doing is aerating the oils to see how much air he can whip into them with and without the lucas... most people should know that keeping oil levels at the proper level avoids any such aeration...
    Dave
    91 Stealth TT- Pampena Stage 2 short block, rebuilt heads, Solid mounts, MBC, Vac reduc, hotwired, Blitz FATT, 4.5" FIPK, TurboXS BOV, Stainless Downpipe, Race pipe, Borla exhaust, AHDS, 500 lb clutch, JDM 25 spline 5 spd/tcase, Short Shifter, EVO leather knob, 18" Mazdaspeed wheels, Front Splitter, in dash touch screen bluetooth/navigation/DVD...
    94 3000GT DOHC - Nitrous express proton series w/ upgraded solenoids, dash mounted datalogger, in dash touch screen navi w/bluetooth, IPT end clutch, high performance trans cooler, Translab shift kit. SOLD
    Quote Originally Posted by hotGTO View Post
    the level of oil in a spur geartrain can be anywhere from 25-75% of the pitch radius, with 50% being the average. The comparison is just above 50%, so the fill level is correct.
    See the effect of fill level, h-bar, on page 64 of the following reference:
    http://www.google.com/url?sa=t&sourc...z9Igfw&cad=rja
    Keeping it real...
    Oct. 2006
    Reno, NV
    Holy Disertation! 100+ pages...Ill have to get back to that.
    No BS
    NJ (south)
    I just don't see how a spinning a gear half submerged like this equates to what is going on inside a full crankcase in a motor, that's my only question... Supposedly when your crankcase is at the "full" level your oil does NOT aerate... That's all I'm saying.
  8. #18
    That is representative of what is going on a transmission or differential. Much less worse than in an engine. Here you have an oil pump creating vacuum and possibly cavitating the oil on the way in, the high pressure galleries feeding main bearings, which then feed conrods (cavitation is actually quite common here). Either that, or they spin around and come out the sides of the bearing shells after 10-50 spins around and aerating.
  9. #19
    Rice Patrol verified
    I run lucas on every oil change on both cars. The Eclipse has bad lifters but with the lucas, you cannot hear them...with just Rotella, they sing in the morning. One thing that that guy is not testing is heat in engines.
  10. #20
    Ann Arbor, MI
    Lucas is great for specific applications, and they have never been cited for FTC violations.
    Neither had Enron or Lehman Brothers!
