Results 1 to 4 of 4
Thread: Power door locks quit working - fuses are good
    Dec 2012
    Arkansas
    The door switch seems fine. Plus I have a parts car (that was totalled) that I have the DS door switch to test with and it doesn't work either. There appears to be always-on power to the two larger blue wires that go to the actuator. The brown striped shows no power.I can move the actuators by hand.
    Neither door works. I am confused by the wires that go to the actual key lock on the door - what they are for?
    Fuses all check out good.
    Any ideas for tracing down issue. These worked before the car sat for about five months.
    Thanks!
    Randy
    Key Largo, FL
    Check your plug connection at the door frame. You might have gotten some corrosion in there causing a bad connection.
    2013 NG: 1st place, FWD Drags
    Medford OR
    Any other ETACS functions not working? does the security system arm?
    Quote Originally Posted by 93STLTH View Post
    Also check the connector in the door jam for broken wires. Its a somewhat common issue.
