Results 1 to 10 of 16
Thread: J spec 6 speed w an RPS carbon carbon clutch upgrade and more!
    The Panda Not Verified
    Washougal WA/Portland OR
    Last week I started pulling out the trans, steering rack, sway bars, and front half shafts to replace with new ones. I'm at a stand still as I'm waiting for the clutch to come and need to order the Addco sway bars from 3sx later today.
    I thought I had lock on a set of Saner sways from Polygon but he screwed me over time wise. I payed him his Full asking price of $500 and 3 days later decided he didn't want to sell then to me as he felt that the shipping was to expensive. He claimed that ups wanted $150 for shipping and so he backed out of out deal instead of trying USPS, FedEx, and Grey Hound. I PM'ed him to try these other methods but No Response! Shady if you ask me!
    New parts to go in:
    Jspec transaxle 0 miles
    5 speed rear end (50,000 previous miles)
    EMPI Front half shafts
    Steering rack
    RPS twin carbon clutch (2000 previous miles)
    Addco AWD sway bars front and rear.
    PST 6 speed two piece aluminum hybrid driveshaft.
    Here are a few pics!
    Had a couple a little time to work on the car today manage to mod the counter weight to fit my intercooler piping.
    I also got my clutch and sway bars in! Unfortunately the flywheel bolts didn't come with it. I can't use the stock ones as they are to long so I order them and should be here in soon.
    Halfway!
    All done!
    Front sway bars compared side by side.
    My carbon carbon twin disk.
    Got the rear addco sway bar in Friday. Did not take many pics. But here are a few.
    New flywheel in for the carbon carbon twin disk.
    How's the fitment on the rear? I don't recall seeing a review on the latest revision.
    The rear subframe is not 100% complete I have new oem end links coming on Tuesday. I will post more pics when it's all done.
    oct.2007...
    Cleveland, Ohio, United States
    Pretty cool you have a lift to this I wouldn't wanna do it in a garage lol
    Almost done just a few things to button up. Anyway here are a few more pics of the sway bars!
    Here is the rear where it hit the floor pan. I used a pry bar to put a small dent. I suspect that this is not needed as when I put load on the suspension it should give more clearance.
    When I was done I could slide the wire with out hitting the floor.
    Shims are required for the front bar only.
    I also added an extra 5 washers per side to the end links or the front for better angles.
    they seem to fit pretty good then. looking forward to a road review, I may start working on the front one today.
    Fitment is ok I think the rear is just about spot on, and love that it uses stock hardware. Front could use a few tweaks.
