Results 1 to 10 of 20
Thread: Throttle Body Rebuild Service
    TN
    ADMIN NOTE: Thread closed per posters request.
    Starting February 1, 2013 I will have to charge $5 more. I will honor the previous price if I already have your throttle body or it's on the way.
    I currently do not have a 96/97 TB core, or a 98/99 core (unless you want a polished one)
    Throttle bodies are completely disassembled, cleaned, exterior bead blasted, re-cleaned to get out any rogue bead material, and put back together. All new bolts are used when I put them back together- Stainless Steel Socket head bolts. Throttle plate has been polished. I also re-coat the spring, spring plate, and dashpot (throttle damper) to prevent rust.
    ISC and TPS sensors have been tested, and the TPS sensor will be set. The ISC have also been cleaned. Since a majority of the ISCs are the original I don't guarantee them. But they do test within specs.
    If your TB is all original, I can guarantee you the shaft seals are shot, as well as the BISS oring. It has nothing to do with the mileage either, because my Spyder had bad shaft seals at 27K miles. If you have done a TT conversion and used your NA TB, you don't even have reinforced seals... you have a rubber collar oring which will not hold boost .
    New parts:
    Mil-Spec Throttle body shaft seals (2)
    New throttle plate shaft screws with Loctite Red and peened
    BISS screw, o-ring, and plug
    ISC/IAC o-ring
    ISC bolts
    FIAV o-ring/gasket
    FIAV bolts
    Dashpot bolts
    New Throttle Body gasket- the metal one
    About Mil-Spec Shaft Seals: Mil-Spec Shaft Seals
    Quote Originally Posted by streettunedmotorsports.com
    MIL.SPEC's High Pressure Throttle Shaft Seals. Sold as a pair.
    These seals keep the throttle plate shaft centered and positioned in the throttle body. When they wear out, they can cause leaks, sticking, and jamming of the throttle plate.
    We tested a car on our dyno at STM with OEM leaky seals...
    Replaced those seals with the MIL.SPEC seals...
    Picked up 20 whp and 20 ft pounds! Holy Boost Leak!
    Price is $120 shipped (USA) + your core. International shipping is extra. You can either send your core in first or pay a refundable core charge (see below for core prices). Core must be complete and useable. If you want to keep your sensors, let me know.
    Core charges:
    *91-93: $50 (the one with the dashpot w/ vacuum line)
    *93-95: $60 (the one with the "black hat" dashpot)
    *96-99: $75 (if I have a core in stock)
    Optional Services:
    *Polished: $60
    *Vacuum port delete: $15
    *FIAV Bypass: $15
    *FIAV Blockoff: $15
    I can usually have them shipped same day as payment, or the next day. If you want a polished one, it will be about a week.
    Have any questions feel free to ask.
    I will send you an invoice through PayPal, PM me with your PayPal address, what year TB, and any addition services you would like.
    Example of 91-93 Rebuilt
    http://www.3si.org/forum/f4/fs-compl...29/?highlight=
    Before/After Polish & Rebuild
    (previously sold)
    VACUUM PORT DELETE
    Tired of the vacuum caps still leaking or dry rotting. Well, I have permanent fix for that. I cut off the vacuum port flush, drill and tap them, and put in a set screw. Guaranteed never to leak or rot LOL.
    Pueblo, CO
    April, must say I love mine! Mnie was leaking and just shitty. Bought one from april and i was impressed. no issues at all ever. Highley recommend doing this. you never realize how many leaks the old ones have. Highly recommend April and great price!
    Free bump!
    -Mike
    Oct 2012
    I think I have a 91 throttle body, but if I wanted a 93-95, would you charge me for the whole core price or just the difference?
    TN
    I guess I can do that... since the 93-95 are not that difficult to find.
    KC
    Maybe i'm missing where I pay for this at? I've got a 93 that needs to be rebuilt and need the FIAV deleted and blocked.
    2009 BMW M3. No cats, intake and tune.
    2003 Acura TL
    1993 3000GT VR4 IPS TD05 E16G 506awhp@22psi Pump 92
    TN
    Quote Originally Posted by jtvr4 View Post
    I forgot to update this thread on here. I will be resuming my service on or a little before April 1. I need to knock out some throttle bodies before I get backlogged, and reorder rebuild parts.
    KC
    That's fine. Can I send you mine ro rebuild in the mean time? I'm not in a rush.
    Pm sent
    PM sent
    Feb 2014
    2002 and 2014
    Hamilton, Ontario, Canada
    Is this service still being offered?
    Sent from my Nexus S
