Results 1 to 5 of 5
Thread: Loud Tapping From The Rear Head
    2007 (17 Years old ;)
    rio rancho (AKA Real Rathole)
    Hey guys I need some help please.
    Back in March my car developed this loud metalic tapping sound from the rear head. I didn't have time or the garage space to work on my car after I installed the front mount oil cooler so my car has been sitting at a friends house. The city came down on me hard for inoperable vehicles. I FINALLY got some free time between work and school to get some actual work done on the car. I replaced the lifters which I thought were the cause.
    Long story short it wasn't. I did upgrade to 3rd gen lifters but it still makes the loud metalic sound from the rear head. I took everything back apart to see what was going on and noticed something. Some of the lifters on the rear head weren't filling up with oil. This is causing some of the rockers to have just enough free play to wobble around under the camshaft lobe to make the loud tapping sound.
    I disconnected the spark plugs and just kept cranking the engine to try to build up oil pressure in my lifters. The rear valve cover was still off so I could try to move them around. After maybe 5-8 minutes of just cranking the engine there was pressure in the lifters. I bolted everything back together and started the car. It ran fine for about 20 seconds then the loud tapping started again.
    I'm sorry for the story book post but I have no idea what could be going on. I'm going to put a mechanical oil pressure guage to check my oil pressure but I think it's weird it's only happening to the rear lifters. And its only some of the rear lifters at that. I think a max of 3 but there's one lifter that is making the most amount of noise. Thanks for any help or advice.
    Chris.
    March 2007
    Muskogee, Oklahoma, United States
    Check your compression. I had a similar problem and did the lifter swap. It sounded like it was coming from the top-end. Even Chris Hill after listening to the vid thought it MIGHT be a wrist pin. When I pulled the motor I found I had spun a bearing.
    That's what I'm dreading. I don't have the time or space to pull the motor though. Also like I said when I unplugged the spark plugs and just cranked the engine for 5-8 minutes and there was finally pressure... A spun bearing could lead to a lack of oil pressure can't it. Also when I was pulling the lifters out of the head they had some shavings on them.
    Jan 2011
    Possibly the piston tapping the head? Drop the engine oil and have a nosey at it
    Thanks for the post man. I actually ran some sea foam in the car a couple times and now the tapping sound is getting quiet. It's no were near as loud as what it used to be. The next couple things I'm going to do is put a mechanical oil pressure guage on the car and check my oil pressure. After I'm going to check my compression and my plugs while I'm at it. Now something that I haven't mentioned yet, my turbos are GONE. i had the car running for maybe five minutes and there was alot of smoke coming from both turbos. There's alot of oil in the intercooler pipes and on the rear tubo there's consistantly oil on the lip of the turbo. I've known my turbos were bad for a while now but is it possible they are pushing so much oil that they are fouling my plugs and robbing oil from properly circulating through?
