Results 1 to 10 of 12
Thread: Supercharger by-pass valve
    Apr 2012
    NorthEast Kingdom
    I'm thinking about installing a by-pass valve on my Maguson supercharger, is it worth the time and money? Also any negative or positive effects on the system in general?
    why? so that you can "stay out of boost? i'm not sure i understand the point.
    The by-pass valve works similar to a BOV on a supercharged application, with one difference: instead of venting the air to atmosphere it takes the boost pressure and by-passes it into the intake. A recirculated BOV works in the same way
    Quote Originally Posted by Prizefighter View Post
    ok, but why? is your supercharged system capable of generating that kind of power to justify it? i just have a hard time envisioning where this is of significant benefit to SC owners (on the 3/s) where virtually every SC application i've ever seen is tuned for < 10lbs of boost. usually less than 8. i'm having a hard time picturing how throttle-lift will damage a supercharger in the same manner it will a turbocharger.
    Mar 2011
    Southeast Kentucky
    A supercharger bypass valve (SBV) is not the same as a blow off value (BOV). A BOV is used to prevent compressor surge, an event that happens when lifting off the throttle of an unvented, turbocharged engine. Without a BOV, high pressure air, trapped in the intake system, would cause a pressure wave that would be forced back into the compressor which can rapidly slow the turbine or even stall it.
    A SBV is a vacuum operated device installed between the throttle body and supercharger. When high vacuum is present opens, equalizing the vacuum pressure through out the intake system which virtually eliminates all the parasitic loss that the SC has on the engine. When you depress the accelerator, vacuum falls and the SBV instantly closes allowing boost to build. Magnuson claims that their MP90 uses less than 1/3 hp when crusing a 60mph.
    In other words its for fuel economy - by preventing boost from building under lite loads.
    I installed my SBV about a year ago and realized about a 2mpg increase in fuel economy. I purchased my SBV from Magnuson, I think I spent about $60 however ever due to hood clearance problems I mounted mine on the bottom side of the SC which was a challenge in itself.
    Hope this answers your questions.
    Quote Originally Posted by ibsorgn View Post
    that makes sense to me.
    Maybe on the 3/S application the SBV is used differently. I had a mustang with a vortech S/C that used the SBV to prevent compressor surge, and I ran just about 9lbs of boost. Maybe the application between centri blowers and the roots type is the main difference.
    Apr 2012
    NorthEast Kingdom
    Are you satisfied with the way the SBV works? Any effect on performance? Could you be more specific about your comment "mounted mine on the bottom side of the SC which was a challenge in itself."
    Many thanks
    Apr 2012
    NorthEast Kingdom
    Many thanks
    I know the Grand Prix's come from the factory with a bypass valve. I, however, do not believe it is located between the TB and the SC. The TB is mounted directly to the SC in that application.
