Results 1 to 4 of 4
Thread: Blow Thru set up
    Newark, DE
    Blow Thru set up
    I need to pick up a couple of things for a blow thru set up.
    Filters; I would like to try having filters directly clamped on to the turbos. Anyone have a good source for filters? Recommend a vendor/site supporter?
    Pigtail for 3.5" GM MAS; basically need the plug to the MAS with wires I can splice to.
    91 AWD TT
    Is that the small plug? I can't remember. If it is, autozone sells just the pigtails for it.
    Caspers Electronics MAF Harness Adapters 108100 - SummitRacing.com
    this should work. its a harness so people can run an LS MAF on there LT engine. just snip off the LT side and you'll have the pigtail you need.
    the basic go fast bits...
    Tuned by Ray Pampena
    Just a fun Daily Driver.
    Newark, DE
    Yes its the 3 wire plug.
    That looks good, I wonder if they have something that will fit stock MAS plug? Would save some splicing and look better...will check it out.
    Looks like Hans has them also...
    http://www.3swarehouse.com/index.php...emart&Itemid=1
