Page 54 of 64 FirstFirst ... 4445253545556 ... LastLast
Results 531 to 540 of 634
Thread: JimVR4 95 Spyder Engine Rebuild
  1. #531
    Sep 2012
    Decatur, TN
    Also she drove well enough that I finally got her down to the gas station 1.5 miles away which was the first time in a year!
    Look on the bright side: Before the rebuild, did you ever go a year on less than a single tank of gas?
  2. #532
    JNS Engineering verified
    San Jose, CA
    Quote Originally Posted by OhioSpyderman View Post
    LOVE IT!!!!
    One question, what is your BOV setup now? Same as before the incident?
    I will explain when you answer...
    Bob.
    BOV is still the Greddy Type-S. I tested it to about 21 psi when I was putting the car together.
  3. #533
    Dayton, Ohio
    Open loop or closed?
    My Spyder runs AWESOME (and sounds great) with an open loop Tial knockoff (better than Zach's real Tial )
    My Stealth struggles with the same bov, not very happy with open loop, has always had super rich trims (which I can't figure out...all stock stuff, no leaks)...
    It seems that open loop is hit or miss by car and even by build....don't know why....
    I KNOW you will sort things out...good luck!!
    Bob.
    Stock 18" 6 Spoke Chromies
    Indiglo Gauges
  4. #534
    San Jose, CA
    Mine is closed loop. Pretty sure that open loop will run rich with the metered air escaping.
    Yeah I must say I have already got past the sickening feeling in my stomach when I turn the key. Now I'm getting more and more confidence in the car again and I've also read a lot about Chrome at this point. I feel like I can get a basic tune without much trouble.
  5. #535
    San Jose, CA
    Man! I just want to fill her up again and AGAIN at this point
  6. #536
    San Jose, CA
    With Greg's help I sorted out the rough idle / cruise issue which turned out to be the right and left bank o2 sensor wire were swapped in my Blackstealth adapter harness. Details http://www.3sgto.org/tuning-engine-e...xperience.html
    She did limp over to the all Mitsu meet in November as you guys may know. I was complaining to Steve (Chargerx3) about how she doesn't run right and he rode with me. I couldn't resist the urge to hit boost so I really didn't demonstrate the problem for Steve.
    Anywhoo - She is now FIXED! The problem was Blackstealth F'd up my clone ECU adapter harness. He had the right bank (1,3,5) and the left bank (2,4,6) o2 sensor wires swapped which basically meant that the car couldn't run properly in closed loop. After swapping them back to the correct positions she idles and runs like a champ. And she pulls like a mofo
    So, from here it is just tuning.
    I have a hot wire that totally skips the power resistors and does the hi/low voltage switching to provide about 10V at idle and 12.5V at WOT. These are measured at the FP hat. Using the Supra pump flow chart that Jeff Lucious posted I should have enough fuel to hit 15 psi on my DR650s
    I also have plans for a fuel pump voltage booster similar to a Kenne Bell BAP. My design goals are for a two step box that does 10V idle and 14-15V WOT with a plug and play connection to the stock harness. No extra wiring will be needed! This should give me enough fuel for 25 psi!
    I also have to put in the EVO399 MAF to allow higher air flow. The MAF and TB size might end up being my limitation in WHP.
    Also have an IPS downpipe and test pipe coming courtesy of the BF sale. Need to hook up the UEGO wideband as well. Fun times ahead!!
  7. #537
    Feb 2011
    Scottsbluff, NE
    I'd be interested in that pump booster you're talking about. If you end up selling them.
    1995 Dodge Stealth R/T Turbo
  8. #538
    Dayton, Ohio
    Awesome news Jim!!!
    Sorry you had to fight it....
    Bob.
  9. #539
    GREASE BUNNY
    VA
    Good job!
    Time to start enjoying your hard work.
  10. #540
    Just a clarification, Antonio's is not the only harness reversed. All builders had the issue as it is in the schematics incorrect.
    Great to see you have officially passed me up! I am still fighting demons as you tune. Awesome stuff sir!
    Sent from the CaveMan Cave!
