Thank you for posting pics of the ac compressor apart, never seen any before.Where did you find the gaskets for the manifold and the top?
I didn't look for them. These were re-used from the donor compressor.
Looks beautiful Jim!
I will, one day, make my undercarriage look as clean as yours.
What is that bracket you have to the left of your exhaust front pre cat?
Never saw all the stock brackets, huh? The small one that bolts to the exhaust is "Protector, O2 sensor" and the larger one is shielding the starter area, I forget the name. Most people probably pull these off and then forget where they go so they never get back on the car![]()
You do exceptionally good work - I'm very impressed, and its not that easy to impress me ;-)
'95 Spyder VR4:
Exterior/Suspension: '99Front End/Rear Garnish; 19x9 370Z forged Rays Eng wheels; CF 575 Hood; Tein S tech (front) and H tech (rear) springs with rear adjustable control arms; Adjustable Front Tein Pillow Ball Mounts.
Interior: Hella TPMS; LCDBC; Remote Top; Interior Rearview Mirror with Temp/Compass/HomeLink.
Brakes: DBA 4000 Slotted Rotors - HPS Pads - SS brake lines.
Performance: Pampena Bell-housing reinforcement; Pampena pistons; Ninja Lightweight Rods; Dynamic Racing Stage 3 heads and Billet DR650s w/9 Blade turbine and Billet actuators; ported I/E manifolds; DSM SMICs; ID1000s; Flashable ECU ('98) - Chrome 2.0; GM 85mm MAF & translator; 3SX Downpipe; IPS Quad tip exhaust; Walbro 450LPH E-85 fuel pump; K&N fuel filter; AEM AFPR; ACT pressure plate MB019; Maximal/Setrab Oil Cooler; 3SX high capacity radiator; 3SX adjustable cam gears; 3SX Poly mounts; HKS Twin Power.
Jim,
What is that mounted in your front grill (front mounted camera)?
I would leave it on jack stands FOR EV ER.....
Bob.![]()
Stock 18" 6 Spoke Chromies
Indiglo Gauges
92 Wheat Beige Metallic Stealth TT (sold 6/14/20)
