Page 38 of 64 FirstFirst ... 28363738394048 ... LastLast
Results 371 to 380 of 634
Thread: JimVR4 95 Spyder Engine Rebuild
  1. #371
    JNS Engineering verified
    San Jose, CA
    Sorry Jim
    Are they leaking or you just being anal? I cant remember exactly what needs to be done but I wouldn't do it unless it was leaking. Oh and before you mate the trans back up put some fluid in it to make sure you didn't screw up the output shaft seal.
    Damnit Jim, I'm a college student, not a mature adult!
    But, I also wouldn't do it unless it was showing signs of leaking, or you were already in there for something else. I did fill my trans (and the tcase) before reinstalling either to make sure that they weren't leaking.
    Haha, expecting maturity from 3Sers??
    Great suggestion to fill it and watch for leaks though don't the axle shafts have to be installed ?
  2. #372
    Sep 2012
    Decatur, TN
    To put fluid in it? Not at all. I filled per the manual, attached to engine, and had it on the hoist and tilted at all directions with the load leveler with no leaks.
  3. #373
    Hmmm, I thought it would leak without axles coming out, and going in. I should of filled before going in...
  4. #374
    Sep 2012
    Decatur, TN
    Well, I could double check it to make sure that it's still filled to the appropriate level, but no leakage for me.
    As an addendum, I don't realllly want to as it feels like the fill plug threading has been somewhat wrecked and will need to be replaced so I'd like to avoid opening it until next time I change fluids. Currently running Synchromesh (cheap and plentiful), but will most likely be switching over to Redline fluids all the way around in about 6k miles when I hopefully have a bit more money to spend on it. This rebuild has ended up with a lot more stuff having to be replaced than I ever anticipated.
  5. #375
    Delaware
    Make sure you let it sit a good 24hrs or so before adding any fluid so the permatex can fully cure.
    Jason
  6. #376
    San Jose, CA
    Jason
    Noted...
  7. #377
    San Jose, CA
    Rear precat blew chunks like a boss
    Opened up the transmission to replace the axle seals and output shaft seal. This is after pounding out the old seal and installing the PS axle seal.
    Removed the mid case to reseal it
    The poppet cover was stuck on after removing the screws. What I should have done was leave a couple of screws in there before separating the cover from the mid case. Springs and balls went flying and fortunately landed close by as the mid case was pointed downward.
    Bell housing went to the machine shop to have the DS axle seal pressed in after I spent 30 minutes and could not get it started straight. This is after cleanup and painting
    Transmission gear sets look great. VCU still in good shape
    An empty shell
    Here you can see just how much gear oil is actually specified. The fill plug is on the right and the drain plug is at the bottom of the end case. The FSM says to fill the 6-speed case until the oil reaches the bottom of the fill hole which means the oil level is slightly below the differential axle seals. This is why I decided to re-seal the mid case after having experienced a small leak for years.
    Inventory of transmission bolts that will be re-plated
    Received a new input spool seal from Ninja Performance after ruining the original one I got from Supercar Engineering. They obviously were from different manufacturers. I thought the Ninja seal was easier to tap in but this time I had the spool in there to help guide it straight
    Inventory of remaining 6-speed T-case bolts to be re-plated. Note the one long one which seals up the through hole in the casting. The end to center case bolts are not shown as they were previously plated.
  8. #378
    Feb 2011
    Scottsbluff, NE
    Looking good Jim
    1995 Dodge Stealth R/T Turbo
  9. #379
    Dayton, Ohio
    Meticulous work sir
    Looking forward to "ignition"...
    Bob.
    Stock 18" 6 Spoke Chromies
    Indiglo Gauges
  10. #380
    Sep 2011
    Might as well send the bell housing to Ray to get it braced.
