Page 36 of 64 FirstFirst ... 26343536373846 ... LastLast
Results 351 to 360 of 634
Thread: JimVR4 95 Spyder Engine Rebuild
  1. #351
    If you pre-load the adjusters too much your wastegate travel will be limited and you may have boost spike or creep.
  2. #352
    Your thread is true car p0rn my friend
    JNS Engineering verified
    San Jose, CA
    I kinda want to get this right before dropping in the motor since it's really easy at this stage to balance them so they open at the same pressure. How would I figure out the right pre-load for my setup?
    Haha, thanks! Hopefully she will be a true p0rn star and her performance will match her looks
  4. #354
    Your 14 PSI on your 12 PSI springs is probably fine. You'll be able to hit 30 PSI if you want with the heavier springs. I had zero trouble hitting 25 psi and mine were not pre-loaded much with the same wastegate setup.
  5. #355
    One fix at a time verified
    Kansas
    What do you guys think about 14 PSI for the WG? With these stiffer Drweldin springs I'm able to set it even higher before I run out of threads on the adjusters. I believe I'll be running up to 25 PSI on the DR650s with 560 injectors.
    I preloaded mine 3 turns. They cracked open at 11 psi and were fully open at 19. I hit 31.6 psi with them without my boost controller being maxed out so you should have plenty of room to go.
  6. #356
    San Jose, CA
    Mounts are back. They went from this
    to this
    to this
  7. #357
    I have asked before, but would someone point me to, or start a thread on setting waste gates? I have not set mine yet.
  8. #358
    Those pampered chef mounts line up perfect! Good choice!
  9. #359
    Basically you apply pressure to both wastegates and adjust them to open at the same time.
    Sent from my RM-845_nam_vzw_100 using Board Express
  10. #360
    San Jose, CA
    Not as much progress this week as I had to go down to SoCal to help my daughter move apartments and celebrate her BF birthday.
    I disassembled the TC and painted the iron casting and the aluminum housings. I had a new output seal pressed in by the machine shop but on Sunday I tried to press in the input seal and I managed to beat it into submission. As a result it will not be cooperating and will have to be replaced.
    I started on the transmission last night after cleaning the major gunk off of it a couple weeks ago. I removed the bell housing and managed to change out the passenger axle seal after several attempts. These damn seals are TOUGH to get square with just a hammer. After 20 minutes of cursing I finally got it started well enough to drive it home. No such luck with the driver's side axle seal but since that one is in the bell housing I just took it to the machine shop along with the flywheel for resurfacing. A little expensive at $65 for the flywheel but they pull the dowels and do a two step resurfacing.
    I failed to notice that the rear DR-650 shipped to me without the O2 housing studs so I ended up having to order some from Cherry Hill. For $20 I added that plastic piece (mudguard ?) that mounts to the crossmember. I'm not exactly sure what is does but it seemed like a good waste of $20. I discovered I had a missing lower timing cover bolt so I added that to the order and when I called yesterday I found out the order was already delayed just for that bolt. Mike is shipping out everything else and will send the bolt when it comes in. Great customer service from Cherry Hill. They might not be the absolute cheapest (and I sometimes forget to code 3SI into the order to get that extra 1%) but these guys ship FedEx cross country to me all the time for minimal charge so I stick with them.
    So just need the studs, a new TC seal, gut the rear precat and I should be able to attach the trans and drop everything back in maybe this weekend.
    Still thinking about the 14 PSI wastegate setting - not sure it's going to be optimal. I guess it depends on how much boost I'm able to run.
