Page 23 of 64 FirstFirst ... 13212223242533 ... LastLast
Results 221 to 230 of 634
Thread: JimVR4 95 Spyder Engine Rebuild
  1. #221
    Medford OR
    Did they already assemble the heads? You know that gasket kit you have coming includes valve stem seals right?
  2. #222
    JNS Engineering verified
    San Jose, CA
    Damnit ! I couldn't tell exactly what it has. Does it have exhaust gaskets?
  3. #223
    Lmao I almost did the same thing!
  4. #224
    Canaan NH
    Yes it has exhaust gaskets
  5. #225
    San Jose, CA
    Thanks. Well at least I can sell VSS to someone. I'm sure plenty of people need them
  6. #226
    Medford OR
    Let me know if Han's is out of them... I doubt it, the intake cams are the same N/A or TT, only the exhaust cams are different. I do have a couple core motors I could poke around in and see if I have a good cam...
  7. #227
    San Jose, CA
    Yeah, It's a J cam from the front bank. I heard that 1st and 2nd gen have different lobes so I'll need the second gen (which I think J already defines).
  8. #228
    Medford OR
    Yep, 1st gen has slightly more lift. I have piles of 1st gen stuff...
  9. #229
    San Jose, CA
    Time for an update. The lifters were not the problem. Using a 3/32 allen wrench I was able to press the check valve inside the bores and pump out the oil. I expect to have no problems pumping them back up with fresh oil when I re-install them to the heads. Speaking of the heads, here they are after the machine shop completed the valve job. Front head:
    Rear Head:
    Block was hot tanked and honed. Cylinders measured out perfectly:
    Crank, cleaned and polished:
    Got a bunch of brackets refreshed and looking new again:
    Holy Batman, this exhaust valve actually melted and reformed !!
    How's this for a new race grind, lol:
    Follow you, follow me:
    The pan cleaned up nicely using a brush attachment on my drill:
    It's a bitch gutting the motor mounts. There is a LOT of oil in the driver side mount. after diggin out the rubber with a hammer and chisel I ended up using a jig saw to cut the inner ring. Then the pin has a ton of rubber that has to be cut off with a razor blade.
  10. #230
    1993 rt/tt Not Verified
    wa state
    Maybe i missed it, but what exactly are you doing to the motor mounts?
