Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Dyno coming up
    Did our Dyno. The ECU was working awesome, but having issues with the Maft or Translater. You can see that on the chart.
    The AFRs are all over the place do to a bouncing Matf signal. No time to Iron it out. Made 3 pulls, 2 Flashes and this is what we are driving home.
    It's not quite what I was looking for , but it will do untill I get these other issues worked out. It's fun as hell. The launch control is damn near perfect.
    I have never made a good launch untill today. The cool thing thing is, it launches exactly the same everytime. Nothing to do with My skills at all. LOL.
    240 wheels HP. and 205 Tq. Revs to over 8000 easily. New red line set for 8000. Got the "no Lift shift" working as well.
    Sorry no video that I know of. Could have been one, if so I'll post it. So this is our current, but much improvable package to date.
    Mods
    2ND place Autocross NG09
    Impressive!
    94 3500gt vr2? verified
    NC
    Nice work! Would like to see what that thing can do once the maft issues are worked out.
    240hp NA is no joke, congrats. that car must be a blast to drive on the street.
    the basic go fast bits...
    Tuned by Ray Pampena
    Just a fun Daily Driver.
    Newark, DE
    No rev limiter? Hope you're ear plugs were in! Good run.
    Sent from garage
    91 AWD TT
    Lots of fun in this car. And for the first time beat a stock VR4s that dynoed. LOL.
    So we are pleased with the results of a first time Dyno with the new flashable.
    Bumped timing 7 deg before 1st dyno, than 7 more, after 1st pull as still had no knock. 2nd pull had knock in a coupls of spots and pull 4 back out in those ares.
    But the real fun is the Launch control. It is so cool to launch and not have to get out of the throttle do to tire spin and hop.
    Thank you guys for taking an interest and supporting the hard efforts we put forth in bringing the NA foreward to a vary respectable performance level.
    Found a vid.
  8. #18
    I AM IMPORT POWER
    Driving Vicki Crazy
    Great Results!
    -Chris
  9. #19
    Would like to submit that Dyno sheet for getting on your "Dyno Database" for NA's.
    Other than I really did not see one.
