Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 80
Thread: Rough closed to open loop transition
    Seems to be anywhere between 2-3k
    Any ideas?
    I did, you still have access to it.
    I derped. I remember looking at the graphs now, and not seeing anything conclusive. I like Greg's suggestion.
    Fowlerville, MI
    I don't know if MMcD can log that, but I can try adjusting the TPS to be sure it'll hit the switch (for testing purposes) and I have a spare TPS I can try.
    VR-3747 :D Not Verified
    Dayton Ohio
    correct me if im wrong (greg) but i was always told that its closed loop till ~3000rpm and then it runs off set fuel maps past that. is that correct, or totally false? maybe its based off throttle position?
    Fowlerville, MI
    It's actually based off airflow and rpm, but you're mostly correct. Once in open loop, it goes of a table based off MAF table and a few other variables.
    Keep in mind that WOT behavior is different from "just driving along" behavior...
    I lack color... verified
    Aug 1998
    It's based of airflow, RPM and TPS.
    The ECU is always using the same maps. Closed loop is just a final correction from those base maps which then gets disabled when airflow and TPS are greater than a certain value at a given RPM.
    Aug 1998
    I think its prudent to find out why the mid fuel trim requires so much enrichment. If there are no vac leaks and the injectors/fuel pressure are 100% without a doubt good then you're correcting your airflow to be too lean. The o2 sensors are going to compensate for any correction (to an extent) so its fairly pointless to do any kind of correction to the airflow signal below 4000 RPMs. Maybe undoing the emanage from the ecu (just the tps and airflow wires) for now might be the best idea to try and diagnos the issue.
  8. #18
    Fowlerville, MI
    TPS is tapped, not spliced (like the MAF). I don't see that doing much, but I have thought of undoing just the MAF. I want to recheck fuel pressures first.
  9. #19
    Aug 1998
    Ah that's right. Forgot the TPS is only tapped. It's been a few years since I installed any piggy backs.
  10. #20
    Fowlerville, MI
    Does MMCD have the ability to log the idle switch? If the ECU doesn't know your foot is off the gas it will keep the ISC set to around 55 counts which is too far open nor will it decrease IPW for decel which can cause the idle hang.
    Checked the idle switch at the sensor and it's working. Scanmaster shows 13% (was 12% before I adjusted it). Wiring to the ECU could be bad, never know with this car.
