Results 1 to 5 of 5
Thread: Which kit.....
    Which kit.....
    So... black friday sales... my current supporting mods are AEM, 720cc injectors, front mount setup, 4 bolt block with forged pistons/rods, stock heads with 1G cams, 3SX dual pump/dual feed setup with Walbro 255's.
    The question is - Would I be better off going with T3 43mm turbos or T3/T4 59mm turbos? I'm concerned about spoolup on the 59mm turbos due to having stock heads.
    59mm. you can always upgrade heads later. mod it with forward-thinking in mind.
    It depends what you are looking for from your car. What are you planning on using the car for?
    Delaware
    I would go with the smaller turbos initially. Hans makes a good point, what are your intentions with the car?
    Jason
    Jan 2011
    az
    Get the 59mm kit . 43mm t3 turbos would probably be a waste of time . Td04 cars would probably make the same amount of power .
