"264" "272" "280" "292" dont mean anything at all... the delta "272" is hotter that the brian crower "280" and the dynamic race spec, i believe its .435 lift and 235 degrees @ .050, very hot cam
might be a different spec... i didnt actually get all of these cams but when i called delta not too long ago they were only offering a "264" and "272" and the 272 was .435 lift... he could have maybe said it wrong but thats definitely what he told me
either way, the point is that the advertised duration just puts you in the ballpark of how aggressive they are, its not an exact spec
yea theyre cheap compared to others, they even provide the shims, definitely call and make sure sure on the spec but the reason i didnt buy them is because i didnt want a cam that hot in my daily driver
Lift is .397 with the delta 272. And the 280 is .402. But the 280 requires solid lifters. The 272 can be shimmed. Does .005 on an inch really a huge difference? I'm guessing in the long run the extra .005 does help? Give some opinions on this.
Talk to brian at FFWD. They can make regrinds for you from cores.
