Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Greddy Multi D/A Guages
    Aug 2011
    Man that's pretty slick.
    1991 Stealth ES (Sold)
    1994 Stealth RT/TT
    1995 3000GT (Sold)
    FYI I found a much cheaper source for this. I also have some feelers out for quotes.
    Evasive Motorsports | PH: 626.336.3400 Mon-Fri, 9am-6pm PST: GReddy D/A Gauge
    Mad JDM Tite
    STL
    Wow that is a sweet discount on the set.
    Avoca, NY
    I'm assuming they're not shipping that for free at that price so I should be able to match their shipped price. Let me know.
    hey fellas quick question. I'm going to run this greddy gauge in a pod or something and keep the stock center three. I'm not a fan of dead electronics in my car, so I'm going to keep the stock gauges all functional. I found some 1/8 BSP tees I believe will work:
    1 8 BSP Male Centre Tee with Female Outlets 3 Way Tee Fitting 1 Off B159 | eBay
    This should fit in the stock oil sender hole and have just enough room to run both senders. Now take a look at the water neck:
    Thanks to intropy for the image.
    The greddy gauges are the same thread as stock and previously I just threaded right into the right most sensor hole with the greddy sender. Now that I want to run both I have too options since I am a 2G.
    1)Remove that plug for the a/c sensor and use that hole.
    2)Use a tee on the normal sensor hole.
    My question then is will a tee work okay for the temp sensor probe. Assuming it physically fits. Does the sensor need to see "flow" to work properly? With a tee it will not really see flow anymore.
    2nd question. What size is that plug? It certainly looks bigger than the gauge sender hole. If I can get that plug out I think I will need a reducer and that may be really hard to find.
    I am aware of the radiator hose adapters they make to mount senders, but it isn't the cleanest approach in the world and introduces another place to leak.
    found my answer:
    1995 3000GT: Defi Coolant Temperature Sensor Installation
    I'd prefer to find a 3/8 bsp to 1/8 bsp though, will take a look.
    found it:
    http://www.ebay.com/itm/5PCS-3-8-Mal...item3cbb7348ac
    It's going to be tight trying to run both oil pressure senders at the same time. I'd like to see pictures of that I you can make them fit. Space is pretty tight around there with the axle and power steering belt.
