Page 1 of 6 123 ... LastLast
Results 1 to 10 of 60
Thread: Boost effects on low compression engines vs high compression engines
    Apr 2012
    NorthEast Kingdom
    What are the benefits of boost on a low compression engine VS high compression engine? Is there really a need to lower your compression ratio if you are going to use sometype of forced induction? If so why?
    Medford OR
    Yes, you will severely limit the amount of boost you can run by using too high compression ratio... The cylinder pressure gets pretty extreme.
    Apr 2012
    NorthEast Kingdom
    Can you be more specific.
    Member
    Quote Originally Posted by Blown3000 View Post
    Too much pressure, engine go boom.
    STL3S Not Verified
    Oct 2005
    How to add a turbo to a non turbo car.
    Some light reading that should break it down simple enough.
    Apr 2012
    NorthEast Kingdom
    Quote Originally Posted by whitedragon View Post
    Have done so now I want to hear from the forum.
    Medford OR
    I'm not sure what you're looking for...? A lesson in simple physics? how a motor works? Maybe I'm not grasping the question, but it seems pretty simple to me... Do you understand why you can't run 20:1 compression in a gasoline motor? If you increase the volume of air in the cylinder by one atmosphere, you've already compressed it 2:1. Do the math, and you'll find that the difference in compression between our N/A motors and turbo motors is no accident...
    Apr 2012
    NorthEast Kingdom
    Sorry, You may think your answer is pretty simple but I'm not understanding what you are trying to say. Why don't you put it in simplier terms and help me with the math!
    wait....aren't you the dude with the supercharged 3/s?
    Apr 2012
    NorthEast Kingdom
    Yes and still running fine.
