Results 1 to 2 of 2
Thread: 92 3000gt valve body problems
    I have a 1992 3000gt sl fwd automatic, it needs a new valve body. Will any year work or just 91-92?
    thanks
    What makes you think it's valve body issue? You know those first gen TCUs pop like popcorn.
    Bad caps in those as well. The TCU's are or can be VIN specific. First gen trans for you only. Plenty
    of trans shop will try to sell you trans from Other Mitsu products and tell you they will work.
    But they will not. If you get a trans from an other car you will need the TCU for that trans.
    AVpro ecu repairs now repairs TCUs as well. Cheaper than new. after all the messin around with our auto,
    we ended up pulling it for a 5 speed. THat and the auto trans could not pull the socks off a dead man.
    SAtill have the trans, and the high stall converter to go with it. But have no TCU anymore.
    What city are you in.
    Mods
    2ND place Autocross NG09
