Huh, turns out 22 is crank and 23 is cam angle sensor ('93 tech info manual).
Seems odd that both would fail at once.
both plugs are next to each other, check for water intrusion or something?
Also make sure that your belt did not rub on the wires. There is just that one little clip holding the wires away from the accessory belt.
Thats always been a fear of mine, but the cas harness was fine. I did secure it better using a clip i found at autozone. The crank pulley and dowel looked good.
I cleaned the cam angle sensor plug with wd40 and compressed air. It started right up... ha. Pulled pretty well (c16).
Good to hear! Always nice when it's simple. Hopefully it does come back.
Bump![]()
Ha.. I dumped more c16 in the tank and the car loves the cold weather. I had to replace the fuel pump in my dad's truck, which caused me to miss the mid november import night.
When's the stroker going in? If you have everything together that's easily done in a weekend![]()
