Results 1 to 10 of 18
Thread: Vacuum Line Issue: Upgrading Throttle Body from SOHC to DOHC
    Silver Spring, MD
    So I have a DOHC throttle body I planned on installing onto my 99 SOHC. I still need to bore my plenum to match, but thats not my issue.
    I noticed that the DOHC throttle body has 1 vacuum line inlet where my SOHC has 2. The vacuum lines in question are labeled P.E.A on the throttle body. The DOHC only has P, and my SOHC only has E. and A.
    From what I've read in the vacuum diagrams I think one line on my SOHC is for EGR. My problem is the diagram only shows throttle bodies with either 1 vacuum line or 3. So now I'm confused as to which line does what, since mine has 2.
    Could I just T of the vacuum line and connect both vacuums to the same port, or will this have negative effects. I read in another thread that a similar setup caused the EGR to stay open all the time, but that guy had three vac lines which I don't.
    Frontline Fabrication verified
    Morgantown, WV
    U can just T it if you need the vacuum port (Vacuum is Vacuum)...After doing a vacuum reduction on my TT I just capped all 3 of the TB ports off
    '95 Passion Red RT/TT
    www.frontlinefabrication.com
  3. The Following User Says Thank You to MeTarzan For This Useful Post:
  4. #3
    You can either T it, or get a later model or Cali spec DOHC TB. My SOHC is Cali-spec so it came with 3 ports on the TB. The DOHC TB I installed was off a fed spec and only had one. I teed it and everything works as it should.
  5. The Following User Says Thank You to stealthee For This Useful Post:
  6. #4
    Silver Spring, MD
    Thanks for the quick responses. I'll T the vacuum off. One less worry for my rebuild.
    Stealthee: With your mod list, did you need a tune? If so any recommendations on what I need? The only difference between your list (in your sig) and mine are
    I have
    .20 overbore pistons
    portmatched intake and exhuast ports on the heads
    Ported air passages for the intake on heads
    Webcam Reground Cams (from 3sx)
    You have
    Custom Cat
    EGR Delete
    Everything else motor related is identical
  7. #5
    I just slapped it on. No real difference noted.
    Ironically, I drove to Silver Spring to pick up my DOHC TB, as well as a some newly cleaned NA injectors when I bought them back in the day.
  8. The Following User Says Thank You to stealthee For This Useful Post:
  9. #6
    Silver Spring, MD
    Ha, I need to update my City. I'm in Burtonsville now. Not much of a difference since its the next town over.
    Once I'm done the build I will post up pics and details. I'm probably going to dyno it too, so I can put up results. Not much info out there for us SOHC's.
  10. #7
    TN
    I would just bore out the SOHC TB and use the DOHC shaft/plate... Hell, I have a SOHC TB with 3 ports you can have if you want to go that route LOL.
    You might have some idle issue with the vacuum if the DOHC came from a pre 96 car.
  11. #8
    I don't have any idle issues. Like I said, my SOHC is Cali-Spec so it really isn't much different from dbeltran's.
    Why bore the SOHC TB when a DOHC is right there?
  12. #9
    TN
    Is your car a 98/99? They changed the way the vacuum is on the 96+ TBs vs the 91-95 TBs. There are actually three variations of the TT TB also.
    If you clean the bore of the TB, you should see some holes on the top (above the plate/butterfly)... the placement, size, and number of holes varies. That is why I said he might have idle issues.
  13. #10
    I looked at the TB off the 98 SOHC engine that went in my car and it looked no different than my stock TB off my 94 Cali-Spec.
