Originally Posted by
nodoze
Third and fourth on the.above question are on the same shift hub so you have a problem with that hub most likely . And as far as weird shift pattern on the OP question could be cause by cables not being placed properly or maybe even your shift shaft going into the trans put in incorrectly with the spring.missing or the reverse serene not lined up when installed .
I don't know how many countless times I shift a trans before i even install it in a vehicle to be sure but the pattern and movements are natural to me and i know what I'm.feeling.for
Sent from my HTC Hero S using Tapatalk 2
