Results 1 to 10 of 10
Thread: Wheel offset
    Wheel offset
    Figured this would help visualize what changes when your wheel offset changes.
    Keep in mind the strut depiction isn't real, and tires are sized slightly differently between brands if you're hoping to keep the same strut/fender fitment. This also doesn't take into account spoke-caliper clearance.
    Online Wheel & Tyre Fitment calculator. Offset, Tyre stretch and Rolling Radius calculator
    Gives results like:
    Added:
    Quote Originally Posted by james92tsi View Post
    I use and recommend this app.
    Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
    Plug in your current and desired wheel/tire packages and it'll tell you how your clearance(s) are going to change so you can measure and look for issues on the car.
    Like any other calculator it cannot account for spoke / caliper interference (which is a huge issue on these cars...).
    found a really good link for people who are complete newbies to this stuff:
    42 Draft Designs
    i don't see the offset listed in your sample pic? i see rim/tire size, but that's it.
    Et38, et28...
    Madison Heights, Mi
    green line vs orange line. Its hard to see the effect of the offset because the width changes as well.
    Quote Originally Posted by ipd View Post
    i don't see the offset listed in your sample pic? I see rim/tire size, but that's it.
    et38
    et28
    I never even scrolled down to see that you answered Kenny for me.
    so what is "e28" and "e38"? that's non-standard nomenclature. offset--for as long as i can remember--has been +/- in mm. negative for outboard, positive for inboard.
    ETXX has been the correct nomenclature for years AFAIK. ET38 is a positive offset, ET28 is still positive. ET-20 is a negative offset.
    May 2012
    Houston, TX
    '91 3000GT VR-4 Silly car, get down from there. You're not a plane. You don't even have wings.
    '03 G35 Sport Coupe Retains transmission and full warranty, even with VDC off!
    42 Draft Designs
    nice find IPD. added
