Results 1 to 2 of 2
Thread: Fault Code P0100
    Jun 2012
    Grants Pass, Oregon
    Fault Code P0100
    Howdy, worked on the car and bumped the MASS Sensor connection and now I have a fault code P0100. I think it's a wire in the connector loose. Are there replacement wiring connectors for these?
    1998 3000GT Base SOHC fwd 5-speed
    Secret Lurker Man! verified
    7/10/06 or somethin
    Bend, Oregon
    No replacements aside from new harness, or acquiring a pigtail from someone willing to cut it off of a parted out car, which would be scarce. What condition are your connections in, on each side? You could try just cleaning it up, with the old dielectric grease, there's a lot of grime that can get built up on the connections. I'd inspect it all and clean everything out spotlessly, the harness side has a rubber gasket inside the pigtail, you can pull that out, spray everything really good with some electric contact cleaner, blow it out till it's dry, put the gasket back in, then clean the MASS side with cleaner, blow it out n make sure everything is completely dry, reapply new dielectric grease and make sure it snaps in nice n tight and see if that doesn't fix your problem.
  3. The Following User Says Thank You to Nihil For This Useful Post:
