Results 1 to 10 of 14
Thread: Hairspray mod
    wheatfield, IN
    Hairspray mod
    Fowlerville, MI
    Yes, and you'll never be able to get them off agian.
    And all for want of a lip.
    Lack of lips is what keeps chickens from smiling.
    i can't see at work.
    Frontline Fabrication verified
    Morgantown, WV
    looks like he needs a better coupler than a rubber one from lowes for drain pipe...my silicone one holds up to 60 pounds on turbos with no lips...
    '95 Passion Red RT/TT
    www.frontlinefabrication.com
    West MI
    not sure what your using if it can hold anywhere near that much without lips.. the best clamps I could find cranked till just before stripping wouldn't hold the silicone couplers on my 13t's with 12 psi of boost.. had to get lips welded on.
    Morgantown, WV
    Quote Originally Posted by Rakuny View Post
    its called a t-bolt clamp...you would break it before stripping the threads... and the reason we test that high is cause the car runs ~54psi.
    I run Mikalor clamps on my lippless FMIC setup and they`re good for 30psi with no movement. The piping is substantial though and you can clamp them down VERY hard..
    West MI
    I've broken T-bolts trying to get them tight enough.
    so it's like lock-tite for couplers. hmmm....i think i'd rather just pay extra for piping with a lip.
