Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 44
Thread: So I'm going on a hiking trip Monday with a good friend.....
  1. #31
    There's is a bit of good in evryone verified
    Quote Originally Posted by Intropy View Post
    Have fun!
    Wait...
    Y'all have fun now, ya hear? There, that's better.
    ahahahaha!
    packing up to go....
  2. #32
    Quote Originally Posted by mdcrose View Post
    If you are taking food and you are in that part of the mountains you need a bear bag. You want to put your food and anything heavily scented in a bag, tie a rope around it and throw the rope over tree limb and pull the bag up to at least 10 feet. Keep this bag away from your tent site and you shouldn't have any bears trying to get in your tent for food.
    At that elevation you probably won't be able to get a fire going with any wood you find on the ground because you will be in the clouds at night and morning so everything will be saturated. It's also going to be considerably cooler at that altitude at night so make sure your gear is suited for low 40's or colder.
    We have a starter log, hopefully that will help. I'm also going to bring some food that doesn't need to be cooked.
  3. #33
    Quote Originally Posted by vr4chick View Post
    ahahahaha!
    You might want to bring some 1st aid stuff. Have fun!
    Large Member
    Tulsa, Ok
    Quote Originally Posted by mcshooter View Post
    not familar with where you are going but i would pack at least a 357 just in case, sometimes the 2 leg critters are the most dangerous
    True. I've heard some crazy stories...
    2010 Toyota Camry SE
    1998 Honda Accord EX
    2005 Jeep Grand Cherokee Limited 5.7L Hemi - Sold (Good riddance!)
    2007 Mazda CX-9 Grand Touring - Sold
    2001 Ford Explorer - AWD 5.0L V8 lifted w/ 32" BFG AT K/O's - Sold
    2004 Mazda6s - Sold
    1994 Stealth RT/TT Pearl Yellow - Sold
    1993 Stealth ES Twin Turbo - Sold
    1981 Audi 4000 4E "The Tank" - R.I.P.
    1984 Toyota Corolla Hatchback - Sold
  5. #35
    got the first aid kit packed. Seans dad offered to let us bring his 40 cal but Sean won't do it....
  6. #36
    Sean and I are off to the Smokys.....
    Wish us luck
    we will post pics if we get cell signal
  7. #37
    good luck and be careful.
  8. #38
    Reconsider the 40 cal
    R.I.P Spyder you are missed. 93 VR4 453 Hp, balanced, Ported, Polished, Port Matched, 99 lifters, Ross 70 over 8.5 to 1 forged pistons, Stress relieved shotpeened magnafluxed rods,EK2 Red poly motor mounts, Fidanza Adjustable Cam Gears,Kevlar timing belt, Polished Fuel Rails, 16 T, Gutted Precats, 3SX performance down pipe, Race pipe,QTP Exhaust 3" Cutout, HKS Cat Back, MSD Wires, NGK BCP7ES non-resistor plugs, AEM EMS ECU, Speed Density Conversion, AEM 3.5 MAP, AEM AIT,Dual K&N air filters, Dejon Tool Dual Air Intake, Dejon Tool Y Pipe, PTE 550, Walbro fuel pump, EK2 fuel loop, No EGR, Vacuum line reduction, AEM True Flow Controller, Greddy BOV, AEM Gauge UEGO Controller wide band O2 sensor, Gauge-Tech, Kormex tranny,Quadco XR steel Output shaft, LSE Stainless Steel Transfer Main case and Midcase, Quadco input spool, Lightened flywheel, South Bend 6 Puck DXD F Clutch, Greddy EGT, Autometer Boost Gauge, 3SX fuel pressure gauge, Cross Drilled and Slotted Rotors, Ceramic Brake Pads, FMIC , 5Zigen FNO1R-C, Audio: 6 New Infinty speakers. Alpine CDA MP3/WWA 9847 Reciever, 2 Dual 300 watt amps. Cianci 3 gauge A pilars, Aluminum defroster vents' lowered
  9. #39
    Large Member
    Tulsa, Ok
    Have fun!
  10. #40
    Large Member
    Tulsa, Ok
    Quote Originally Posted by FastOldGuy View Post
    lol....
