Results 1 to 9 of 9
Thread: Electrical buzzing help
    Everytime I start my vr4 and take off, I hear an electrical buzzing/motor for about 3 seconds. I have already removed the active exhaust: switch,actuator motor and module that are located in the rear left hatch. I have also removed my AA rear spoiler, switch and module from the rear left hatch. My antenna does work, I can clearly hear it as soon as I turn on my stereo. I have removed my cruise control: switch, module, and relay. I dont think my vr4 has the front AA, I cant seem to find it in front, can some one post a pic of one? Is there any AA/AE relays or other components that I might be missing? Any one know what it can be?
    Anyone? This thing is driving me nuts. I always back out of my drive way and turn the wheel, when I go into first gear, then I give it some gas and start straightening the wheel, thats when I hear it. If I turn off the car for about 30min then start driving I dont hear it.
    you still have the solinoid rack on the firewall? ABS?
    No solenoid rack anymore, yes to abs.
    I removed my yellow 60amp ABS fuse and the buzzing is gone, meaning somthing wrong with ABS. I read that the relay behind the passenger fender goes bad, I replaced it and reinstalled my 60amp fuse and the buzzing is back. Buzzing lasts about 3 seconds only when I first start driving and it wont do it again until I turn the car off and start driving. Any idea?
    do your lights dim at the same time? Might be a frozen ABS pump motor. when you start moving the ABS pump motor turns on for a sec to test the system.
    ^ not sure havent checked the lights, is there a problem if it keeps buzzing or should I remove the fuse again? How do I fix it?
    depends on what exactly is buzzing, one of the pump relays or the motor itself. Does the ABS light come on during the dash light test on first key or does it come on after the buzzing?
    It comes on on the during the dash light test on first key, not during the buzzing.
