I am having an issue with temp sensor. I was doing some fine tuning on the car now that I have it running better. I noticed my coolant temp on the AEM tuner screen as soon as I start the car and connect to the ecm the temp goes up and up on the aem not my gauge. I also put a mech gauge on it the engine never goes over 185 degrees farenheit. But the AEM is reading 269 degrees Farenheit to 296 Farenheit. I replaced all of the temp sending unit includeing oem gauge even though it was working fine. I am puzzled. Ran down the wiring no damage to the wiring. I also made sure that the correct type of sensor is turned on in parameters. Is this normal with the larger liquid cooled turbos or did I just get a bad set of new sensors? Anyone else have a similar issue?
