I JUST ordered an ACT HDSS kit from Maximal.. As I know my current clutch is bad. The site says that a "throwout bearing" is included. Is that the spring that you were referring to?
No. The springs are in the hub of the clutch. The TOB is what the clutch pedal engages. It slides on the input shaft via the release fork.
A bad TOB can cause issues too, but you would know it if your TOB were bad, because you wouldn't be able to shift, period.
the FWD trans parts can be ordered through normal dealers like cherry hill.
