Results 1 to 10 of 15
Thread: 5 Speed Tranny Rebuild
    Audio Fanatic
    May 2012
    Around January, Im going to get my 5 speed n/a transmission rebuilt. I have 150k miles on it and experiencing a few issues. I dont want them to escalate.
    Currently, 2nd gear requires more "work" to get into than any other gear, but it doesnt grind. Could the issue with that just be a synchro?
    3rd gear "randomly" grinds. It'll grind once every 3 or 4 weeks. Im thinking of replacing that gear and synchro.
    Reverse can be tricky to get into. Sometimes I have to play around (Go into 1st and then back to reverse once or twice) to lock into reverse all the way.
    Because, the tranny will be pulled.. Im going to just replace the clutch, flywheel, and throwout bearing.
    So, Ill most likely be getting 2nd gear and synchro, 3rd synchro, reverse synchro, and Exedy 05048 clutch kit. What else normally goes out with these trannys?
    Im planning on ordering the 2nd gear and the reverse synchro from 3SX and clutch kit from Amazon. Are there any cheaper alternatives?
    Where can I get the 2nd and 3rd gear synchros?
    I have a mechanic who I go to for all of my work. Are these transmissions unusual, or should the average mechanic be able to do all the work?
    Audio Fanatic
    May 2012
    ttt
    not sure how the pricing is, but Phil at supercarengineering.com has them.
    I wouldn't even order trans parts until you open up your transmission. If 2nd is giving you a lot of issues, then you probably need a new gear and hub/slider assembly. The dog engagement teeth on the 2nd gears like to get worn down to straight angles instead of looking like triangles.
    Audio Fanatic
    May 2012
    For FWDs? I checked online, but maybe i missed it. It shoot them an email later.
    When the car is off, my car shifts into second (along with all other) gears just fine. Could the issue still be the hub/slider assembly?
    Adjust your clutch pedal before you go thinking you have other problems.
    Audio Fanatic
    May 2012
    That's actually the first thing I did
    You might also only be having a clutch problem, like a weak spring.
    Audio Fanatic
    May 2012
    Would the weak spring cause my clutch to not fully disengage?
    Yes, it could.
