Whether you get H or S techs, you may or may not have to install the adjustable arms. It has been hit and miss on what I have read elsewhere. I had the same ??? about 6 months ago and went with S techs, I am wanting coil overs now! Springs and arms are gonna be around $400, and double for for entry level coil overs.
I love the ECS with S techs. You get a comfy ride and when you want good cornering with stiffness. I just want the car lower now and want to autocross soon...
I found the front ECS struts for $126.00 on one of the mitsu parts sites...
My experience,
Bill
Sig is with S techs...
yep its all it does, doesn't do much els!
all it is is fluid that escapes to and forth from one cylinder to another cylinder and back again via a series of holes to slow it down.. nothing magical just a damper. even with ecs its the exact same thing only its controlled by an actuator that opens the holes wider or closes them back to original size.
makes no odds if the strut is way at the top or way at the bottom (provided it doesn't bottom out...but iit cant the spring will become coil bound first).
Thanks for the support, guys. I am convinced enough to go ahead with the Teins. Will only cost me $140 more than stock, as the shop will charge me more labor to reinstall the stock springs over the shorties.
[SOLD] Black '92 R/T TT
Tein H springs
K&N Airfilter
(119,000 miles -- original owner)
huh?
its the same job! you mean they will charge more to fit a set of lowering springs than they will a set of stock? i'm confused! please explane this to me.... in the shops words!
its exactly the same job to remove the struts and fit whatever springs you want, no deviation from stock to lowered.
if anything they should charge less because the car wont sit as high
Colt, you got it backwards. As I stated, the shop will charge less with lowering springs -- my guess is because they won't need to compress them, as the nut will thread onto the strut with Teins without using the compression tool The $140 increase is what it would cost me for Teins minus the upcharge w/o Teins. Make sense?
Maybe, I should just try and do it myself?
Its an easy job to do yourself. The stockers come apart by just getting an air gun on there, pointing them away from you and zapping the bolt off. I have done it about 3 times so far on my own car and twice for friends.
Make sure you use a penetrating oil a day or two before you or anyone else does the job!!!!
The nut 9 times out of 10 will snap the strut at the top and you will be spending more coin for new ones. If one breaks you should replace both.
The shop will not pony up for busting it either...
