Sooo I deleted my AC yesterday (with IPS delete kit) and everything went ok, car started ran no issues for over 100 miles until I saw the temp gauge climb...
Timeline:
I drove into town from my dads (roughly 15 miles) went to see a movie car was fine.
Drove all the way through downtown and then left stevens point headed for Madison.
Got 70 miles everything seemed normal. Stopped at a rest stop and noticed that there was steam coming from my hood.... Checked the temp gauge, looked fine. Ok checked under the hood and there was coolant blown everywhere. Both overflow tank and the filler cap were on securely. Checked all the hoses couldn't really fine anywhere it could be coming from.
HMMMM. I was worried but it was still running normal temp, coolant levels were fine, so I just decided I would try to limp it back to SP as I was only about 20 miles out.
No go, got about 10 miles away from the rest stop and saw the temp gauge start to climb. pulled over and called a flatbed. Got it towed back to my appt and put in the garage.
Looking at it after getting it back off the tow truck, the driver pointed out. Your fan is unplugged..... WHOOPS.
I think I caught it in time where nothing REALLY bad happened. Temp gauge started to climb and I immediately pulled over and shut it off. I can't see anything else I forgot to connect sooo I think I can just refill with coolant and make sure to "burp" it and get all the air out. Overflow reservoir is full up to the top (which it wasn't) so I'm pretty sure there is air in the system.
I didn't hear anything from it but I hope I didn't fuck up the water pump :/ Although the 180K service is coming up here so it will get replaced soon anyways. I don't think I did any damage.
Please let me know if there is anything else I should check. We made sure coolant was full and it ran fine for a lot of miles city and highway without issue and I can't think of anything else it could be.
