Results 1 to 10 of 15
Thread: 3000GT VR4 VS. Stealth TT Main Gauge Cluster
    I'm Kind Of A Big Deal
    Who would have thought they were different?
    This is a US Spec Stealth TT Main Gauge Cluster (top), and a JDM VR4 main gauge cluster (bottom)
    Notice the red circles? That is the space for the active aero light.
    You can swap the bulbs into it, I assume, you would just have to drill/pierce a hole through the green stuff.
    Just a little food for thought.
    Current:
    2004 ML500 - Mommy Mobile
    1995 3000GT VR-4 - lawn gnome
    1999 3000GT SL - 7,436 miles
    FOR SALE:
    Oregon
    According to my JDM GTO owner's manual, it was an available option, although I'm sure it was discontinued after 1995 like ours. Do you know what year car the cluster came from?
    Mark
    94 VR4
    There's no replacement for displacement.
    Canaan NH
    Bottom right corner the top pic has a light the bottom one doesnt have.
    that's the security light. Not all of them had it.
    Quote Originally Posted by Markingtime View Post
    the JDM one has active aero (same as the VR4s). The stealth one (the one above that doesn't have a bulb in the spot), doesnt have a bulb/cut out for the active aero light bulb indicator... so, if you were to install it in a VR4... if it got a signal that there was an issue with the active aero, the light would never turn on... since there isn't one there.
    Key Largo, FL
    That's the "Looking Good!" light, which, of course, the 3000GT doesn't have.
    2013 NG: 1st place, FWD Drags
    Canaan NH
    Quote Originally Posted by 93STLTH View Post
    HAHA well played.
    cut the hole out, removed the green plastic from over the copper so it makes contact with the bulb... problem solved
    So yea... just an fyi to anyone buying a gauge cluster... they're different, but it's fixable.
    Brisbane Australia
    Just as well the GTO has an even bigger "looking good" bulb than the Stealth
    "Video games don't affect kids, I mean if Pacman affected us as kids, we'd all be running around a darkened room, munching pills and listening to repetitive music."
    PIONEER-ODR RS-K1/C-100/C-200/RS-P50 X2/RS-P1/RS-M1
    DIAMOND-AUDIO HEX 8" X2/HEX SILK DOME TWEETERS X4/D7-401 AMP X2/D7-402 X1/D7-152 AMP X1/D7-104 AMP X1 ETON 4-300/25HEX 4" X4 AUDIO-CONTROL EPIC-160
    ECLPISE 10" TITANIUM (SUBSONICS) X2 SW9102
    PHOENIX-GOLD 12" CYCLONES (INFRASONICS) X2 DC SERVOS http://webfaq.phoenixphorum.com/cyclone.htm
    FUSION 7 COLOUR L.E.D KITS X4 2 MODIFIED. Intergrated lighting through out install.
    1994-MITSUBISHI-GTO-TWIN-TURBO-4WD-4WS-FULLY OPTIONED-SERIOUSLY being MODIFIED
    July 2005
    Arkansas
    Or just undo the screws and move the plastic circuit board over.
