ya its good stuff, i used to use it on chrome trim pieces, its a very easy but effective way to clean things up.
And the list goes on...
I also used Neverdull on my first ship. That was 34 years ago.
It's been around a while.
Thought I start showing my current rebuild so this is as good a place for it as any. 1992 Pear White Stealth RT/Twin Turbo
http://gallery.me.com/maxetaylorjr/1...12903841600001
Wisco Pistons with new bores, Forged Crank, ARP Rod Bolts with ARP Bottom end & Head Studs, Stage 3 ported and polished heads with Brian Crower 272 cams, 3SX Adjustable Cam Gears, TD04 19T's, and supporting hardware.
Valve Covers and Plenum are polished aluminum, not chromed. All engine brackets sanded, primed and given several coats of gloss Red Engine Enamel.
Can't wait to get everything up and running. Will keep you posted.
