Sorry for my stupidity and off topicness but what is the benefit of MR gears, and MR gears are only in 6speeds right? Again, I really know nothing tranny wise about these cars.
'MR' is a misnomer, as far as we know all JDM 6 speeds had different ring & pinion gears within the tranny and used a 5spd rear end. So fittingly we call them 'JDM' gears, not 'MR' gears.
I'm not aware of any difference between USDM & JDM 5 speed gearing though. Did Mitsu even make a 1st gen GTO MR?
Here's an online caps, I posted it before, it probably could use a sticky-ing:
http://www.akadia.ru/_pages/mitsubis...I3LmpwZw%3D%3D
I think either the plate or CAPS has an error. CAPS number is MR111883.
Probably doesn't make any difference but some odd things in the pictures could be due to the possibility that it may have come out of a "Right Hand Drive" vehicle. Just a thought.
Yeah MR is the Mitsu part number prefix, NOT from an MR edition GTO.
The only interesting thing about that trans is the piece attached to the shift linkage. Haven't seen that on a 5sp before.
^ you mean the counter weight?
And the list goes on...
Part number MR111883 is a replacement for part #: MB936206. Between these 2 part numbers it covers all TT version of the 5 speeds. Nothing special about it from what I can tell. However ASA/CAPS doesn't tell you anything about the gearing. However if it's a replacement for the standard gearbox then we have to assume it's the same gearing.
Waiting install
Build Thread
