Results 1 to 10 of 17
Thread: sequential ignition
    Forum User supporter
    Bounemouth, UK
    sequential ignition
    Just an update about my AEM 8 Channel CDI & AEM short Coil On Plugs.
    As I have the 8 channel CDI, I decided to go with Sequential ignition instead of wasted spark. I had a problem with the brand new AEM EMS 2, pin 91 which is the dedicated pin for number four coil was not working, instead of going through the hastle of sending the EMS off to the US, I got a local ECU repairer to fix it and now everything is working OK.
    The main reason that I went with sequential ignition is that it enabled me to lose the PTU as well as the coil packs tidying up the engine.
    Below are a couple of pics showing the setup, the blue wires going to the COP's are just covers, there are just two thin wires going to the COP's.
    The CDI is under the stainless cover on the left of the engine bay, this is because one of the vents in my PRM hood is above it and the rain was soaking the unit.
  2. The Following 2 Users Say Thank You to Tigchamp For This Useful Post:
  3. #2
    How's the twin fire working for you? Mine would work fine until the engine got warm. Then it would misfire like crazy and make the car fall on it's face. I suspect it might be my ptu so I swapped another one in. Next step is removing the ptu altogether, but I like having the bypass plug option.
    1992 3000GT VR4 - 11.97@117.99 w/ craptastic 1.83 60ft 20PSI
    Mods- Billet DR650's and other crap
  4. #3
    Bounemouth, UK
    Quote Originally Posted by Rebel View Post
    To be fair I dont know yet as the car has not been on the road yet, although I hope to get it maped in the next two weeks and then we will see.
    If you have a 8 chanel cdi I used the wiring on page nine which enabled me to remove the PTU.
    Jeff
  5. #4
    Banned J. Fast's Avatar
    - O - SIX -
    Colorado, USA
    Your build turned out so great! Congrats on everything. Go enjoy it! BTW, the COP upgrade is awesome. What was the dwell and charge difference between the OEM vs the COP?
    Bounemouth, UK
    Just a quick update, car is now on the road, CDI & COP'S are working fine at all temp's.
    I dont beleive in running in engines so just putting a few hard miles on it to loosen it up before taking it in to be mapped.
    I dont think I have to worry too much about knock as the TD05 20G's are only boosting to 12psi at the moment and there are big black clouds of excess fuel followed by 6ft flames coming out of the exhaust (running a bit rich lol)
    Jeff
    San Francisco, CA
    Love it. Can't wait till you turn it up.
    AEM s2 EMS | E316Gs | E85
  8. #7
    Quote Originally Posted by Tigchamp View Post
    I know this is an old post but I'm very interested in doing the same thing on my set up to take advantage of the knock-per-cylinder detection/control of the AEM EMS series 2. I don't suppose you could share your setup details, like part numbers for coils, part numbers for coil drivers, specifics on dwell settings, etc.? Your engine bay looks very clean.
    Thanks,
    -Greg
  9. #8
    Bounemouth, UK
    Quote Originally Posted by SpikeyGG View Post
    Thanks,
    -Greg
    Sure Greg,
    The coils I used are AEM 30-2850. If you are going AEM you can only use the 8 channel CDI as there are not enough coil outputs on the 4 channel one.
    I used the instructions for wiring the coils to CDI on page 9 of the AEM 8 Channel CDI manual.
    When you go into the coil setup in the AEM EMS 2, the crank settings are there for the other three coils you just need to check the box.
    Jeff.
  10. #9
    Bounemouth, UK
    The coil drivers on the AEM EMS 2 are as follows.
    Coil 1 - pin 10
    Coil 2 - pin 23
    Coil 3 - pin 11
    Coil 4 - pin 91
    Coil 5 - pin 82
    Coil 6 - pin 85
    You will note that although my AEM EMS 2 was brand new in the box, pin 91 was faulty and did not work so I had to get it repaired.
    You will find more info in this thread, http://www.3sgto.org/3000gt-stealth-...t-rebuild.html
    Jeff
  11. #10
    Jeff, thanks for the response! You only mentioned turning on coils #4-#6 but did you also disable #1B, #2B and #3B?
    My current setup looks like this:
    It looks like I need to turn off the 'B' coils and turn on 4, 5, and 6 but also copy the "Coil Phasing" values from the 'B' coils to their respective new coils.
    Also, did you need to change any of the advanced pickup options like "Spark Teeth"? I've been reading on these options and the base map I started with seems to already be configured to sequential ignition even though my ignition is the stock wasted spark setup. The following screen shot shows what I'm talking about. Wheel Teeth is set to 6 and so is Spark Teeth.
    I'll have to check my pin 91/coil#4 to see if it's busted too.
    Thanks again. I'm getting excited about running sequential ignition!
    -Greg
