Just thinking for a moment, 20K seems like a whole lot of spring for a 3000lb car. That's 1100lbs of rebound per spring on a corner. I bet it unloads aircraft style unless you have double that in aero to keep it planted. Doesn't sound achievable without a tubular or superbody chassi? What kinds of 3000lb cars are we discussing here? Unlimited's ?
Hahaha, I was just being silly about the bent frame comment.
A number of the Vipers are in the 2000lb spring range. I think if you ask around you'd find a lot of the faster cars are way up there in spring rate.
I had my buddy (the other Jake) take a ride with me and help setup the suspension. This is the driver I just posted over the weekend that took 5th in F1000 down at COTA that I sponsor. A super great guy that you have to hang with. I raced with him for a few years through the SCCA. In a brief nutshell you just want the suspension to not bounce on rebound. A nice compression with a swift rebound without any oscillation or hop. (higher dampening rate will slow this) I'm honestly a little worried about how long the JIC's will be able to take this amount of spring since it's darn near twice what they had in mind when they made them. I'm two clicks from maximum on the front, rears are one click of the bottom, but I don't want max. I want it to be able to absorb at a fast rate but not not be so stiff that it doesn't have time to absorb. Basically, the lowest setting possible without any bounce.
Some say..."you can never have enough spring". But I think that was from a kart driver. :P
