Nice so your gonna drive it or trailer it over ??
15 hr tow each way with the Montero![]()
I know. Just worried something stupid will hold up tuning like a fuel pump going out or bad injector, etc. Seriously thinking about buying spares of the usual suspects that cut dyno time short so I am prepared! (FPR, fuel pump, coil pack, etc)
I would definitely bring spare OEM ignition components preferably new and also a few sets of spark plugs. It wouldn't hurt to bring some new vacuum lines and couplers too although you really shouldn't have a problem there not running high boost. The only other thing could be a fuel pump or fuel filter issue. I'm sure it will be relatively trouble free though.
The coilpack I have I bought from youDefinitely will have plugs, couplers, clamps. I have a spare newish coil pack and wires. Really thinking about buying a walbro 416. I only need one pump for my current power goals and I don't like the idea of two pumps. I guess 1 of my 340's might be close enough though just in case one gave up.
It's a loooong drive and to end up having a few hundred dollar part hold us up, so trying to think ahead. Who wants to road trip with me??![]()
Ordered the gopro roll bar mount last night. Looking forward to finally using it.
Nice! Didn't realize you had a roll bar/cage...Custom or pre-bent setup?
Really? I've had it since 2005 when they told me not to come back to the track without it. S&W racecars mild steel cage. Definitely messed up the first cut on the DS door bar, so it is really low and won't do much in a wreck... But it gets me through tech and doesn't make getting into the car suck too badly.
'05:
'12:
I really want that same cage setup you have.
Post via Tapatalk
