I wouldn't say that the aftermarket radiators are less efficient, rather that most aren't able to fit the stock fans with the larger radiator, and that most aftermarket "slim" fans are garbage.
Well, the 3SX single pass radiator had not been out for too long, my car was at 3SX a few years ago and running a little bit warm, and I was told that would probably be the fix. Of course, at the time, I think I was running flex-a-lite fans and no splashguards underneath, so that was more likely the problem.
mishimoto aluminum, both stock fans (rad and ac), 3sx td05's fit for me with some trimming. I have a 4" FMIC, uncut bumper, active aero tray; I deleted A/C and crash bar and added an extractor vent. Works great so far at 80's temps. We'll see how it does now that we are close to 110* in the shade. Hopefully will be driving again within the next week and can report.
Thinking about trying to fit a/c with my setup, but I'd get a new condenser. The old one I removed had lots of blockages and crud in fins. If you are having heat problems and haven't done so yet, definitely blow rad, fmic, and condenser fins out with compressed air.
Has anyone fit a half width ac condenser on driver side only? Not sure if it would dump enough heat to cool interior well enough, but would definitely help radiator on one half.
I wasn't going to be able to use a stock condenser fan on the driver side, even if I trimmed it. The fan motor still wouldn't clear the wastegate dump tube for me. However, I could easily see your set up working fine, especially with your a/c removed. My temps stay less than 200 degrees when a/c is turned off when its 87 outside, and most people shouldn't have problems. I have an unmodified crashbar in place too, which is probably blocking some of the airflow. Temps only start creeping up when the a/c is turned on. I haven't driven it long enough yet, but the highest i've gotten it was 210 degrees as it slowly crept up at idle. Turn the a/c off, temps go back down.
I plan on taking the crash bar out just for an experiement, but it will end up going back in. If temps drop due to increased airflow from removing the crash bar, then I will get it modified, but I am not going to go without the crash bar at all more than just experimenting.
I may experiement on the radiators this summer. As the OP said he had better luck, I may try to pick up a good used TT sized radiator for cheap, throw it in, and see if it makes any difference.
Be careful picking up a used stock radiator. Some are over 20 yrs old now! I replaced mine because internally the fins were corroded. (I think someone in my cars past, filled with tap water and ran some nasty additive in coolant.) I figured clean aluminum would transfer heat better than gunked up copper.
If I did it, I wouldn't keep it for a permanent solution. I was just looking to see if it actually makes a difference, and if the 2" radiators are or are not superior. I would run the same two fans I have on now for comparison. Then it would come off. If it worked better, I would get a new one. I would just hate to spend the money for a new stocker only to find out it really doesn't work any better, even if I run two a/c fans.
I've never not run an OEM radiator and ive never had a temp problem. Todds car with a 3.5" thick FMIC, a/c and stock hood, stock everything(the DR750 car) has zero temp problems with a 20 year old used stock rad.
Jason
I'll never not run an OEM radiator personally. I plan on getting the copper cored Denso copy myself for the 99 since i am rocking the original and would like a new one since it'll be basically the only non-new thing under the hood.
FWIW Ray P's chameleon car ran the stock radiator
Jason
