The HHH cable will only work with HHH software, I've tested that one myself.
IIRC someone on here built cables back in the day for around $20 I want to say, can't remember who though.
Yeah I bought the coupler.
The cable that HHH sells with it's computer program will not work with MMCd, in my experiances at least.
The HHH cable will work. The cables are the same for data transmission. HHH just uses those heavy XLR connectors.
Serial com error is usually due to a bad connection somewhere. Most likely it is in the cable somewhere Both the standard logger cables and the HHH cable are based off of this:
Now the connector connected to your OBD1 port, What does it look like?
Also make sure your coupler is a pass-through and not a crossover.
I sent mine off to Rymer when I got my ECU fixed and he got all of the wiring corrected on it. I had issues with two different cables and was thinking my ECU was bad. Bought a new ECU to find out both logging cables I had were bad. Rymer got them working for me.
Side note. Has anyone been able to export out to excel with MMCD Tools?? For some time now I have not been able to export out to Excel. Only CSV which drives me nuts as I need to get the raw data out also.
I really need to sit down and look into fixing a bunch of issues I have with this software. I have the core files but I need to get the damn environment set up to get everything fixed!!!!
[IMG][/IMG]
Cable looks in great shape, I see no crimps, or loose connections or exposing wires, I reseated the connectors back into the port exactly like they were, no difference. I wouldn't think they were in the wrong spot to begin with. The coupler doesn't say anything about it being a cross over, it says its used to simply extend a cable to make it longer, so it shouldn't affect signal I would think.
I couldn't tell anything from the pic of the connector. But if it doesn't say "null modem" on the side of it, it's probably just a sraight through gender changer, and won't work...
