Page 150 of 892 FirstFirst ... 50100140148149150151152160200250650 ... LastLast
Results 1,491 to 1,500 of 8916
  1. #1491
    Apr 2011
    Mid-April 2011.
    Monroe WI
    I have two on mine...
  2. #1492
    You have a solid bushing in each ring under the center column?
  3. #1493
    Never finishes any verified
    Wake Forest, NC
    Where is the "one need one bushing"? The ebay one you posted looks like the underhood bushings.
    Quote Originally Posted by Blackmount View Post
    You can see in this pic that the one on the lower right that is attached is really small. There really is not a rubber bushing in that one. The otehr one has the solid one in it hence buying the kit and only using one. That solid bushing is the same ones that are used under the hood.
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
  4. #1494
    All over
    Found out the bolt to the front motor mount was missing so installed a new bolt smooth shifting now
  5. #1495
    Apr 2011
    Mid-April 2011.
    Monroe WI
    Oh I was speaking of the bushings on the transmission side.
  6. #1496
    I guess this qualifies as doing something to my 3S.
    Brake duct entrance piece CFD simulation:
  7. #1497
    Apr 2011
    Mid-April 2011.
    Monroe WI
    Cut up my shitty short shifter, welded parts from stock shifter on it... Its now a pretty nice shifter , added new bushings, and adjusted linkages. Bolt action shifting is win.
  8. #1498
    West MI
    What I did today..
    New dust shields and wheel bearings
    also bought these..
    evo 9 MR Bilsteins!
    when the car is done I will set it down on them to weigh the car and get the information needed for Bilstein to revalve the shocks to my specifications. I'll also be fitting coilover sleeves, etc.
  9. #1499
    August 2010
    Chicago
    Just contacted the ebay seller for a set of bushings...can't wait to get mine.
  10. #1500
    you know you like it Not Verified
    Sacramento CA
    I think I got my coolant leak fixed at the drain petcock by replacing the petcock... So far no leaks
