Results 1 to 10 of 29
Thread: Sub Box
    Sub Box
    I am needing help confirming a dimension in the hatch area of our 3s.
    It would be the width between the wheel wells WITH the trim still installed. I have been going by 39" max but IIRC, that was a little on the small so I knew without a doubt that it would fit.
    So anyone who has built a box between there what fits back there snug? Because I want to keep the box below the sunroof, my height is limited to 12.25". So every bit of width I can squeeze in there will help.
    Honda Eater
    April 2007
    Ontario, Canada
    i have two 12" subs that i would like to hide so i have some room in my truck for my baseball/hockey shit... right now i have a box that slightly touches my rear window, which im surprised, hasn't shattered yet lol.
    Any dimensions?
    Thanks for dumping on my thread. Sorry I am building for something smaller than 12's.
    Mad JDM Tite
    STL
    You need to clarify your question. The spacing between the strut towers varies with height. And I'm guessing you mean the sun shade that covers the rear hatch area so you can't see behind the rear seats right?
    I need to know the widest a sub box can be and fit between the wheel wells or strut towers I know I can go 39 wide but I want a snug fit
    Mad JDM Tite
    STL
    You still aren't really answering the question for me so let me try again. Are you wanting a box that just sits in the back so its easily movable or a box that contours to the back? Additionally are you planning on using the space between the rear seats and the strut towers to mount the box? You also mention ditching the spare tire stuff, is that just so you have a spot to mount your amp(s)?
    Do you want to keep the back seats? The easiest way is to just pull out the seats and build a platform for the box to sit on. Then you can just go out and buy a generic box from anywhere and stick it right in.
    I have NEVER just gone out and bought a "generic box". A box needs to be built to the specs of the sub that you are using. And no backseat delete for me.
    With the exception of the head unit, sub box and tweeter pods. the goal is to hide it. And with the tweeter install, anyone who doesn't know that car would think that they where there from the factory.
    It started with a challenge from my best friend, a "stealth" install in a Stealth. At first I just blew it off, but then the thoughts started flowing, and I cursed him but accepted the challenge.
    Should be fun.
    Should be fun.
    Generic as in not made specifically for the car. Obviously you have to use a box to meet the specs of the subs but most sub boxes today are built with this in mind. I wouldn't take it for granted though.
    Are you thinking of running a shallow mount sub under the carpet like this...
    Or maybe a setup that works with the back seats still installed. I know I have seen it done I just can't find the picture...
    I will be removing none of the interior, except the spare tire stuff.
