Results 1 to 10 of 17
Thread: Which Head is Which?
    On a 2nd gen set of heads, how does one tell which head is which, the front or the rear.
    I have an extra 2nd gen head and I'm not sure if it's the front or the rear. It was disassembled at some point so I can't tell which side it was used on but if the loosely placed cam caps are any indicator, it was a front head, but looking on the side where the cam caps are, I can see the two holes for the Cam sensor bolts, where it would be installed.
    Are the 2nd gen heads reversible?
    Excellent!
    I was worried that the front head didn't have the mounting location for the Cam Sensor.
    Texas
    It can be pretty easily identified which is which by looking at the mounting place for the thermostat housing. The timing belt side of the heads are going to have the caps blocking the holes.
    That's what I would normally check, the caps, but the head has been disassembled and the caps were kind of just sitting there, no way of knowing where they originally sat.
    I've been told that the head can be reversed so if you turn a front head around it becomes a rear head basically. I seriously hope this is true.
    Ugh, frustrating conflicting information.
    I have one head from a '94, it's totally stripped down so I can't tell what's what.
    Stealthee, are you sure that the 94+ heads still have the CAS sensor mounting location? I'm being told by other people otherwise, that with 94+ heads, you can use them on either side because they're identical.
    No, one 91-92 you can you use them on either, but not on 93+.
    Rice Patrol verified
    I got 2 sets of 93 heads here and they are identical.
    Hmmm. I must be remembering different then. I could have sworn there was a difference. I guess I could have went to my garage and looked and the 93 engine sitting on the floor to find out for sure. I'll take your word for it and note it for future reference.
    alamogordo, nm
    the front and rear head are the SAME, thy just mount opposite from each other on the motor.
    91-92 TT heads are the same front/rear
    93-99 TT heads are the same front/rear
    93 RT TT 8.74@168.5mph @3600ft Worlds Quickest and Fastest 3000gt/stealth
    2001 Dodge Viper GTS Heads/cam/Paxton 873 rwhp & 803 rwtq
    95 RT TT 604 awhp 611 awtq (DR750's, and stock motor)
    2004 F350 Harley 14.4@90mph at 3600ft
    04 Lambo Gallardo (sold)
    95 3000GT VR-4 10.56@136mph- 714 AWHP & 607 AWTQ (dr-900's) (sold)
    92 Stealth RT TT 10.69@133.45mph @3600ft (dr-800's) (sold)
    95 RT TT 10.88@129.1mph @3600ft (sold)
    There are 2 ways to make a car fast.
    #1 use the Right combo of parts
    #2 Throw so much money at it that the car has no choice but to be fast.
    I choose #1
    Click for US 3S Fastest ET list
    Better to be a racer for a moment then a spectator for a lifetime
    "Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education alone will not; the world is full of educated derelict."— John Calvin Coolidge
    Huh? verified
    Detroit Area, MI
    Damn, no wonder my vr4 isn't running 9s yet, I switched the heads around! '93+ heads are all the same.
    1993 3ooogt vr4
    Big single turbo and every other mod...
    Powered by BorgWarner
