Results 1 to 10 of 15
Thread: Guys who have flushed their system...
    Cazenovia, NY
    How much did you use. I'm buying ATE Super Blue fluid for $12 a liter... I don't want to buy 2 liters if it's not necessary
    is 1 liter going to be enough?
    Forum User Not Verified Feedback Score 0 GordonRamsey's Avatar
    Earth
    I used half a liter with my RBF600. Was enough for all four corners. Doesn't seem right though.
    “What's the use of a fine house if you haven't got a tolerable planet to put it on?”
    Member Not Verified Feedback Score 2 (100%) Erron Spalsbury's Avatar
    Well, to truely flush the system you should be using two bottles total. If you want to get every bit of the fluid out that has absorbed water, it just takes that much.
    You should be good with one, My system was empty, i put in new lines and didnt even use a whole bottle.
    -Austin@STM
    And the list goes on...
    supporter
    Feedback Score 3 (100%) OhioSpyderman's Avatar
    Dayton, Ohio
    -Austin@STM
    WAY off topic, just thought you might want to know that your Exterior/Interior link appears broke....
    "Not Found
    The requested URL /3s/3s_exterior.htm was not found on this server."
    Just trying to help and LOVE what you've done with your car FOR this platform!!!
    Bob.
    95 Caracus Red Spyder VR4
    Stock 18" 6 Spoke Chromies
    Indiglo Gauges
    92 Wheat Beige Metallic Stealth TT..Winter DD!!
    Oldest son - 94 Danube Blue VR4
    Yes that section is still being worked on, so its not an active link yet.
    supporter
    Dayton, Ohio
    Gotcha...sorry, just trying to help
    No problem appreciate the input
    Why do you go RR, LF, LR, and RF? Shouldn't you do longest lones to the shortest lines? RR, LR, LF, RF? That's how I was told to do them anyway.
    I ALWAYS use a liter just to be on the safe side. I have a small syringe I use to suck the master cyl dry (saves pumping another 200mL+ through) and then fill it with the new stuff. Also good to have some spare to top up, and if your a manual, you can bleed the clutch at the same time. but I always buy more then less.
    To do a full flush and make sure you get ALL the old brake fluid out,... still doesn't take a full liter. Maybe 600ml to 750ml at most and that's with Stoptech's ST40 calipers up front which take more fluid than Mitsu's Sumitomo calipers. I can of ATE is good.
    You would only potentially need more than 1 can if you screw up and get air in the system and need to rebleed everything over again. The way I do it, I alternate between SuperBlue and Typ200, the different colors make it easy to see the new fluid. I make sure the master cylinder is full and then make sure to top up every 7 pumps (takes about that many to lower the level in the cylinder, but not be in danger of ingesting air in the system).
    I use Speedbleeders as I tend to bleed solo. Keep pumping and topping up till I see new fluid come out the bleeder tube (I use a Speedbleeder bag. It has a clear tube that is attached to a clear bag. Makes it real easy to see the fluid coming out and it further reduces the chances of an air bubble going up the tube. Once I see new fluid coming out, I give it another 7 pumps before I move to the next corner.
    The order is Right Rear, Left Front, Left Rear, Right Front.
    Max
