Results 1 to 8 of 8
Thread: Carrier Bearing Question
    Forum User verified Feedback Score 1 (100%) Blurr's Avatar
    I remember a while ago, someone in Sweden (I think) was making polyurethane carrier bearings but I don't remember what happened to that whole project.
    It got me thinking. Is there an optimal range of flex that you want a carrier bearing to have. I mean, would it be detrimental to have solid carrier bearings? Obviously too soft and you'd have unwanted shaft movement (That's what she said! Ooooohhhh hehe jk -_-), but is it possible to have a carrier bearing that is too stiff?
    Even if those poly carrier bearings were available (which I don't know if they are), would you really want them to be less flexible than a set of new stock bearings?
    Forum User Feedback Score 0 AudioPmp23's Avatar
    Colorado
    Free bump, I'd like to hear about this. I ended up doing the zip tie method and to my surprise 3 years later they are still holding.
    Canaan NH
    Zip tie method? Please explain.
    Elko, Nevada, United States
    I tried the zipties this weekend and apparently need stronger ties...they kept breaking when I tightened them against the rubber surrround
    Colorado
    You go to home depot, buy a bag of the 4 foot zip ties, route them around the carrier bearings and voila!
    Canaan NH
    Haha. Thats interesting. I have considered filling the rubber surround with silicone.
    Woah! Zip tie method... Hmm... Might just have to do that before I drive to cali. That's a very interesting idea.
    I bought some 75 ftlb rated zip ties from home depot (the thinner ones) and installed two per carrier bearing. Everything looks good so far and after a test drive around my neighborhood including some spirited acceleration, I checked to see if they stood up and they're still fine.
    I was going to buy the thicker, 175 ftlb rated zip ties but I wasn't sure if they would fit through the slots. Having installed the thinner ones, I think they might. If these break before I get my new carrier bearings in, I'll try the thicker, more durable model.
    Installation is very easy. You don't really need any tools. I found that if I slide the zip tie through the slot on the driver side, it easily wraps around and comes out of the passenger side slot all by itself. I wasn't able to get the zip ties to wrap around start from the passenger side slot, they encountered some resistance every time, I'm not sure why.
    I now have significantly less vibration while driving. I'm very happy that I installed them as a temporary fix while I wait for my replacements to come in.
    I'll post an update if I make it to Fallbrook CA from Vegas without them breaking.
